vserver nfs connected-clients show
Display List of recent NFS clients information
The `nfs connected-clients show ` command displays information about currently connected NFS clients, other NFS clients that are are currently idle but can be connected, and a list of recently unmounted clients.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Use this parameter to display information only about the specified node.
[-vserver <vserver>]- Vserver-
Use this parameter to display information only about the specified vserver.
[-data-lif-ip <IP Address>]- Data LIF IP Address-
Use this parameter to display information only about the specified data LIF IP.
[-client-ip <IP Address>]- Client IP Address-
Use this parameter to display information only about the specified client IP.
[-volume <volume name>]- Volume Accessed-
Use this parameter to display information only about the specified volume.
[-protocol <Client Access Protocol>]- Protocol Version-
Use this parameter to display information only about the specified protocol.
[-idle-time <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Idle Time (Sec)-
Use this parameter to display the time elapsed since the client sent the last request for this volume.
[-local-reqs <integer>]- Number of Local Reqs-
Use this parameter to display a counter tracking requests that are sent to the volume with fast-path.
[-remote-reqs <integer>]- Number of Remote Reqs-
Use this parameter to display a counter tracking requests that are sent to the volume with slow-path to remote Dblade using a CSM session.
The following example displays the connected clients information.
cluster-1::*> nfs connected-clients show Node: vsim1 Vserver: vs1 Data-Ip: 10.140.72.214 Client-Ip Volume-Name Protocol Idle-Time Local-Reqs Remote-Reqs --------------- ---------------- -------- ------------- ---------- ----------- 10.140.137.57 rvol1 nfs4 2h 13m 56s 9 0 10.140.137.57 vol1 nfs3 6m 51s 14 0 10.140.137.57 vol1 nfs4 1d 2h 5m 53s 16 0 3 entries were displayed.
