ONTAP 9.12.1 commands
system service-processor network auto-configuration show
Display Service Processor Auto-Configuration Setup
The system service-processor network auto-configuration show command displays the names of the IPv4 and IPv6 network subnet objects configured in the cluster that the SP uses for automatic configuration.
The following example shows that the SP is configured to use the "ipv4_test" IPv4 subnet in the cluster for the SP automatic network configuration.
cluster1::>system service-processor network auto-configuration show
Cluster Name         SP IPv4 Subnet Name          SP IPv6 Subnet Name
cluster1        ipv4_test       -
