ONTAP commands
network interface failover-groups create
Create a new failover group
The network interface failover-groups create command creates a grouping of failover targets for logical interfaces on one or more nodes. Use this command to add a new network port or interface group to an existing failover group.
-vserver <vserver> - Vserver Name
Use this parameter to specify the name of the Vservers from which this failover group is accessible.
-failover-group <text> - Failover Group Name
Use this parameter to specify the name of the logical interface failover group that you want to create.
-targets [node>:<port],…​ - Failover Targets
Use this parameter to specify the list of failover targets (network ports, interface groups, or VLANs on a node) belonging to this failover group.
The following example shows how to create a failover group named failover-group_2 containing ports e1e and e2e on node Xena.
cluster1::> network interface failover-groups create -vserver vs0 -failover-group failover-group_2 -targets xena:e1e,xena:e2e
Looking for answers?
Try Doc, our Gen AI Assistant.
