ONTAP commands
storage disk set-foreign-lun
Sets or Unsets an array LUN as foreign
The storage disk set-foreign-lun command sets or unsets a specified array LUN as foreign. This command will enable/disable the feature of importing the data from foreign LUN.
-disk <disk path name> - Disk Name
This parameter specifies the array LUN which is to be set or unset as foreign.
-is-foreign-lun <true> - Is Foreign LUN
If the parameter value specified is true then array LUN is set as foreign. If the parameter value specified is false then array LUN foreignness is cleared.
The following example shows how to set an array LUN as foreign:
cluster1::> storage disk set-foreign-lun -disk EMC-1.1 -is-foreign-lun true
The following example shows how to mark an array LUN as not foreign:
cluster1::> storage disk set-foreign-lun -disk EMC-1.1 -is-foreign-lun false
Looking for answers?
Try Doc, our Gen AI Assistant.
