ONTAP 9.12.1 commands
cluster peer offer show
Display outstanding offers to authenticate with a peer cluster
The cluster peer offer show command displays information about authentication offers still pending with potential peer clusters. By default, the command displays information about all unexpired offers made by the local cluster.
To display detailed information about a specific offer, run the command with the -cluster parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-cluster <text>] - Peer Cluster Name
Selects the offer that matches this parameter value.
[-auth-status-operational {ok|absent|pending|expired|revoked|declined|refused|ok-and-offer|absent-but-offer|revoked-but-offer|key-mismatch|intent-mismatch|incapable}] - Authentication Status Operational
Selects the offers that match this parameter value.
[-offer-creation <MM/DD/YYYY HH:MM:SS>] - Authentication Offer Creation Time
[-offer-expiration {MM/DD/YYYY HH:MM:SS | {1..7}days | {1..168}hours | PnDTnHnMnS | PnW}] - Authentication Offer Expiration Time
[-initial-allowed-vserver-peers <Vserver Name>,…​] - Vservers Initially Allowed for Peering
[-offer-creator <text>] - Authentication Offer Creator
[-encryption-protocol-proposed {none|tls-psk}] - Encryption Protocol to Be Used For the Relationship
The following example displays information about the outstanding authentication offers:
cluster1::> cluster peer offer show
        Allowed
Peer Cluster Name       Authentication Creation            Expiration          Vserver Peers
cluster2                absent_but_offer 7/11/2013 22:22:52 7/11/2013 23:22:52 vs1,vs2
