cluster peer offer show
PDF of this doc site
Creating your file...
Display outstanding offers to authenticate with a peer cluster
The cluster peer offer show
command displays information about authentication offers still pending with potential peer clusters. By default, the command displays information about all unexpired offers made by the local cluster.
To display detailed information about a specific offer, run the command with the -cluster
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-cluster <text>]
- Peer Cluster Name-
Selects the offer that matches this parameter value.
[-auth-status-operational {ok|absent|pending|expired|revoked|declined|refused|ok-and-offer|absent-but-offer|revoked-but-offer|key-mismatch|intent-mismatch|incapable}]
- Authentication Status Operational-
Selects the offers that match this parameter value.
[-offer-creation <MM/DD/YYYY HH:MM:SS>]
- Authentication Offer Creation Time-
[-offer-expiration {MM/DD/YYYY HH:MM:SS | {1..7}days | {1..168}hours | PnDTnHnMnS | PnW}]
- Authentication Offer Expiration Time-
[-initial-allowed-vserver-peers <Vserver Name>,…]
- Vservers Initially Allowed for Peering-
[-offer-creator <text>]
- Authentication Offer Creator-
[-encryption-protocol-proposed {none|tls-psk}]
- Encryption Protocol to Be Used For the Relationship-
The following example displays information about the outstanding authentication offers:
cluster1::> cluster peer offer show Allowed Peer Cluster Name Authentication Creation Expiration Vserver Peers ----------------------- -------------- ------------------- ------------------- -------------- cluster2 absent_but_offer 7/11/2013 22:22:52 7/11/2013 23:22:52 vs1,vs2
