security key-manager external gcp show
Display Google Cloud KMS configuration
This command displays the Google Cloud Key Management Service (GCKMS) configuration.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
If you specify this parameter, then the command displays only the GCKMS configuration for the given Vserver.
[-project-id <text>]- Google Cloud KMS Project (Application) ID-
If you specify this parameter, then the command displays only the GCKMS configuration with the given project id.
[-key-ring-name <text>]- Google Cloud KMS Key Ring Name-
If you specify this parameter, then the command displays only the GCKMS configuration with the given key ring name.
[-key-ring-location <text>]- Google Cloud KMS Key Ring Location-
If you specify this parameter, then the command displays only the GCKMS configuration with the given key ring location.
[-key-name <text>]- Google Cloud KMS Key Encryption Key Name-
If you specify this parameter, then the command displays only the GCKMS configuration with the given key name.
[-state {available|not-responding|unknown}]- Google Cloud KMS Cluster State-
If you specify this parameter, then the command displays only the GCKMS configuration with the given state. The state can be either available or unknown.
[-unavailable-nodes <text>]- Names of Unavailable Nodes-
If you specify this parameter, then the command displays only the GCKMS configuration with the given unavailable-nodes.
The following example lists all Vservers with GCKMS configuration.
cluster-1::>security key-manager external gcp show
Vserver: SAMPLE_VSERVER
Project ID: SAMPLE_PROJECT_ID
Key Ring Location: SAMPLE_KEY_RING_LOCATION
Key Name: SAMPLE_KEY_NAME
Key Ring Name State
SAMPLE_KEY_RING_NAME unknown
Unavailable Nodes: node1
