security key-manager external gcp show
Display Google Cloud KMS configuration
This command displays the Google Cloud Key Management Service (GCKMS) configuration.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
If you specify this parameter, then the command displays only the GCKMS configurations for the given Vserver.
- [-project-id <text>]- Google Cloud KMS Project (Application) ID
If you specify this parameter, then the command displays only the GCKMS configurations with the given project id.
- [-key-ring-name <text>]- Google Cloud KMS Key Ring Name
If you specify this parameter, then the command displays only the GCKMS configurations with the given key ring name.
- [-key-ring-location <text>]- Google Cloud KMS Key Ring Location
If you specify this parameter, then the command displays only the GCKMS configurations with the given key ring location.
- [-key-name <text>]- Google Cloud KMS Key Encryption Key Name
If you specify this parameter, then the command displays only the GCKMS configurations with the given key name.
- [-state {available|not-responding|unknown}]- Google Cloud KMS Cluster State
If you specify this parameter, then the command displays only the GCKMS configurations with the given state. The state can be either available or unknown.
- [-unavailable-nodes <text>]- Names of Unavailable Nodes
If you specify this parameter, then the command displays only the GCKMS configurations with the given unavailable-nodes.
- [-privileged-account <text>]- Google Cloud Privileged Service Account
If you specify this parameter, then the command displays only the GCKMS configurations with the given privileged account.
- [-caller-account <text>]- Google Cloud Caller Service Account
If you specify this parameter, then the command displays only the GCKMS configurations with the given caller account.
The following example lists all Vservers with GCKMS configuration.
cluster-1::>security key-manager external gcp show
            Vserver: SAMPLE_VSERVER
         Project ID: SAMPLE_PROJECT_ID
  Key Ring Location: SAMPLE_KEY_RING_LOCATION
           Key Name: SAMPLE_KEY_NAME
     Caller Account: SAMPLE@CALLER.COM
 Privileged Account: SAMPLE@PRIVILEGED.COM
Key Ring Name                                State
SAMPLE_KEY_RING_NAME                         unknown
Unavailable Nodes:                           node1
 PDFs
PDFs
