ONTAP commands
security key-manager external gcp show
Display Google Cloud KMS configuration
This command displays the Google Cloud Key Management Service (GCKMS) configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
If you specify this parameter, then the command displays only the GCKMS configuration for the given Vserver.
[-project-id <text>] - Google Cloud KMS Project (Application) ID
If you specify this parameter, then the command displays only the GCKMS configuration with the given project id.
[-key-ring-name <text>] - Google Cloud KMS Key Ring Name
If you specify this parameter, then the command displays only the GCKMS configuration with the given key ring name.
[-key-ring-location <text>] - Google Cloud KMS Key Ring Location
If you specify this parameter, then the command displays only the GCKMS configuration with the given key ring location.
[-key-name <text>] - Google Cloud KMS Key Encryption Key Name
If you specify this parameter, then the command displays only the GCKMS configuration with the given key name.
[-state {available|not-responding|unknown}] - Google Cloud KMS Cluster State
If you specify this parameter, then the command displays only the GCKMS configuration with the given state. The state can be either available or unknown.
[-unavailable-nodes <text>] - Names of Unavailable Nodes
If you specify this parameter, then the command displays only the GCKMS configuration with the given unavailable-nodes.
The following example lists all Vservers with GCKMS configuration.
cluster-1::>security key-manager external gcp show
            Vserver: SAMPLE_VSERVER
         Project ID: SAMPLE_PROJECT_ID
  Key Ring Location: SAMPLE_KEY_RING_LOCATION
           Key Name: SAMPLE_KEY_NAME
Key Ring Name                                State
SAMPLE_KEY_RING_NAME                         unknown
Unavailable Nodes:                           node1
