event notification destination delete
Delete existing event destinations
The event notification destination delete command deletes an event notification destination.
The following system-defined notification destination is configured for your use:
  • snmp-traphost - This destination reflects the configuration in "system snmp traphost". To remove snmp-traphost addresses, use the system snmp traphost command.
-name <text> - Destination Name
Use this mandatory parameter to specify the name of an event destination to be removed.
The following shows the examples of deleting event notification destinations:
cluster1::> event notification destination show
Name            Type        Destination
    StorageAdminEmail
                    email       StorageAdmin@example.com
    StorageAdminSyslog
                    syslog      example.com
    snmp-traphost   snmp        10.30.40.10 (from "system snmp traphost")
    3 entries were displayed.
cluster1::> event notification destination delete -name StorageAdminEmail
    StorageAdminSyslog
                    syslog      example.com
    2 entries were displayed.
cluster1::> event notification destination delete -name Storage*
    1 entries were displayed.
