event notification destination delete
Delete existing event destinations
The event notification destination delete
command deletes an event notification destination.
The following system-defined notification destination is configured for your use:
snmp-traphost - This destination reflects the configuration in "system snmp traphost". To remove snmp-traphost addresses, use the
command.
-name <text>
- Destination Name-
Use this mandatory parameter to specify the name of an event destination to be removed.
The following shows the examples of deleting event notification destinations:
cluster1::> event notification destination show Name Type Destination -------------- ---------- --------------------- StorageAdminEmail email StorageAdmin@example.com StorageAdminSyslog syslog example.com snmp-traphost snmp 10.30.40.10 (from "system snmp traphost") 3 entries were displayed. cluster1::> event notification destination delete -name StorageAdminEmail cluster1::> event notification destination show Name Type Destination -------------- ---------- --------------------- StorageAdminSyslog syslog example.com snmp-traphost snmp 10.30.40.10 (from "system snmp traphost") 2 entries were displayed. cluster1::> event notification destination delete -name Storage* cluster1::> event notification destination show Name Type Destination -------------- ---------- --------------------- snmp-traphost snmp 10.30.40.10 (from "system snmp traphost") 1 entries were displayed.
