network arp show
Display static ARP entries
The network arp show command displays static ARP entries present in a given Vserver. This command will not display dynamically learnt ARP entries in the network stack. Use the network arp active-entry show command to display dynamically learned ARP entries in the network stack.
{ [-fields <fieldname>,…​]
Use this parameter to display only certain fields of the ARP table.
| [-instance ] }
Use this parameter to display all the fields of the ARP table.
[-vserver <vserver name>] - Vserver Name
Use this parameter to display ARP entries that are specific to a given Vserver.
[-remotehost <IP Address>] - Remote IP Address
Use this parameter to display ARP entries for the specified IP address
[-mac <MAC Address>] - MAC Address
Use this parameter to display ARP entry for the specified MAC address
[-ipspace <IPspace>] - IPspace
Use this parameter to specify the IPspace associated with the Vserver
The following example displays static ARP entries from the Vserver vs1.
cluster1::> network arp show -vserver vs1
Vserver     Remote Host       MAC Address
vs1
            10.238.0.2        40:55:39:25:27:c1
