ONTAP 9.12.1 commands
metrocluster show
Display MetroCluster configuration information
The metrocluster show command displays configuration information for the pair of clusters configured in MetroCluster.
This command displays the following details about the local cluster and the DR partner cluster:
  • Configuration State: This field specifies the configuration state of the cluster.
  • Mode: This field specifies the operational mode of the cluster.
  • AUSO Failure Domain: This field specifies the AUSO failure domain of the cluster.
[-periodic-check-status ]
If this option is used the MetroCluster periodic check status is displayed.
The following example shows the output of the command before MetroCluster configuration is done:
clusA::> metrocluster show
  Cluster                         Entry Name           State
  Local: clusA
          Configuration State  not-configured
                   Mode  -
          AUSO Failure Domain  -
  Remote: clusB
                   Mode  -
The following example shows the output of the command after MetroCluster configuration is done only for some DR groups:
  Local: clusA
          Configuration State  partially-configured
                   Mode  -
  Remote: clusB
                   Mode  -
The following example shows the output of the command after MetroCluster configuration is done:
  Local: clusA
          Configuration State  configured
                   Mode  normal
          AUSO Failure Domain  auso-on-cluster-disaster
  Remote: clusB
                   Mode  normal
The following example shows the output of the command in switchover mode:
  Local: clusA
                   Mode  switchover
  Remote: clusB
          Configuration State  not-reachable
                   Mode  -
          AUSO Failure Domain  not-reachable
The following example shows the output of the command when -peridiodic-check-status option is used:
clusA::> metrocluster show -periodic-check-status
       Cluster                        Periodic Check Enabled
        Local: clusA                  true
       Remote: clusB                  true
