metrocluster show
Display MetroCluster configuration information
The metrocluster show command displays configuration information for the pair of clusters configured in MetroCluster.
This command displays the following details about the local cluster and the DR partner cluster:
Configuration State: This field specifies the configuration state of the cluster.
Mode: This field specifies the operational mode of the cluster.
AUSO Failure Domain: This field specifies the AUSO failure domain of the cluster.
[-periodic-check-status ]-
If this option is used the MetroCluster periodic check status is displayed.
The following example shows the output of the command before MetroCluster configuration is done:
clusA::> metrocluster show
Configuration: -
Cluster Entry Name State
Local: clusA
Configuration State not-configured
Mode -
AUSO Failure Domain -
Remote: clusB
Mode -
The following example shows the output of the command after MetroCluster configuration is done only for some DR groups:
Configuration: -
Local: clusA
Configuration State partially-configured
Mode -
Remote: clusB
Mode -
The following example shows the output of the command after a MetroCluster IP configuration is done:
Configuration: IP-fabric
Local: clusA
Configuration State configured
Mode normal
AUSO Failure Domain auso-on-cluster-disaster
Remote: clusB
Mode normal
The following example shows the output of the command after a MetroCluster FC configuration is done:
Configuration: Fabric
Local: clusA
Mode normal
Remote: clusB
Mode normal
The following example shows the output of the command in switchover mode for a MetroCluster IP configuration:
Local: clusA
Mode switchover
Remote: clusB
Configuration State not-reachable
Mode -
AUSO Failure Domain not-reachable
The following example shows the output of the command when -peridiodic-check-status option is used:
clusA::> metrocluster show -periodic-check-status
Cluster Periodic Check Enabled
Local: clusA true
Remote: clusB true
