metrocluster show
Display MetroCluster configuration information
The metrocluster show
command displays configuration information for the pair of clusters configured in MetroCluster.
This command displays the following details about the local cluster and the DR partner cluster:
Configuration State: This field specifies the configuration state of the cluster.
Mode: This field specifies the operational mode of the cluster.
AUSO Failure Domain: This field specifies the AUSO failure domain of the cluster.
[-periodic-check-status ]
If this option is used the MetroCluster periodic check status is displayed.
The following example shows the output of the command before MetroCluster configuration is done:
clusA::> metrocluster show Cluster Entry Name State ------------------------------- ------------------ --------------------- Local: clusA Configuration State not-configured Mode - AUSO Failure Domain - Remote: clusB Configuration State not-configured Mode - AUSO Failure Domain -
The following example shows the output of the command after MetroCluster configuration is done only for some DR groups:
clusA::> metrocluster show Cluster Entry Name State ------------------------------- ------------------- --------------------- Local: clusA Configuration State partially-configured Mode - AUSO Failure Domain - Remote: clusB Configuration State partially-configured Mode - AUSO Failure Domain -
The following example shows the output of the command after MetroCluster configuration is done:
clusA::> metrocluster show Cluster Entry Name State ------------------------------- ------------------- --------------------- Local: clusA Configuration State configured Mode normal AUSO Failure Domain auso-on-cluster-disaster Remote: clusB Configuration State configured Mode normal AUSO Failure Domain auso-on-cluster-disaster
The following example shows the output of the command in switchover mode:
clusA::> metrocluster show Cluster Entry Name State ------------------------------- ------------------- --------------------- Local: clusA Configuration State configured Mode switchover AUSO Failure Domain auso-on-cluster-disaster Remote: clusB Configuration State not-reachable Mode - AUSO Failure Domain not-reachable
The following example shows the output of the command when -peridiodic-check-status option is used:
clusA::> metrocluster show -periodic-check-status Cluster Periodic Check Enabled ------------------------------ ---------------------- Local: clusA true Remote: clusB true
