system node autosupport check show-details
Display detailed status of AutoSupport subsystem
The system node autosupport check show-details command displays the detailed status of the AutoSupport subsystem. This includes verifying connectivity to your vendor's AutoSupport destinations by sending test messages and providing a list of possible errors in your AutoSupport configuration settings.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node <nodename>]- Node
Selects the check results that match this parameter value. This parameter specifies the node whose status is being displayed.
- [-check-type <Type of AutoSupport Check>]- AutoSupport Check Type
Selects the check results that match this parameter value. This parameter specifies the type of AutoSupport check being performed.
- [-status {ok|warning|failed|not-run}]- Status of the Check
Selects the check results that match this parameter value. This parameter specifies the result of this AutoSupport check.
- [-error-detail <text>]- Detailed Description of Error
Selects the check results that match this parameter value. This parameter specifies the detailed error message for this AutoSupport check.
- [-corrective-action <text>]- Corrective Action
Selects the check results that match this parameter value. This parameter specifies a description of how to correct any errors seen as part of this AutoSupport Check
The following example displays the detailed status of the AutoSupport subsystem for a node named node2:
cluster1::> system node autosupport check show-details -node node2
Node: node2
Category: http-https
          Component: http-put-destination
             Status: ok
             Detail: Successfully connected to "support.netapp.com/put".
Component: http-post-destination
             Status: ok
             Detail: Successfully connected to "support.netapp.com/post".
Category: smtp
          Component: mail-server
             Status: ok
             Detail: Successfully connected to "mailhost.netapp.com".
             Status: ok
             Detail: Successfully connected to "sendmail.domain.com".
             Status: ok
             Detail: Successfully connected to "qmail.domain.com".
Category: on-demand
          Component: ondemand-server
             Status: ok
             Detail: Successfully connected to "support.netapp.com/aods".
Category: configuration
          Component: configuration
             Status: ok
             Detail: No configuration issues found.
 PDFs
PDFs
