system node autosupport check show-details
PDF of this doc site
Creating your file...
Display detailed status of AutoSupport subsystem
The system node autosupport check show-details
command displays the detailed status of the AutoSupport subsystem. This includes verifying connectivity to your vendor's AutoSupport destinations by sending test messages and providing a list of possible errors in your AutoSupport configuration settings.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <nodename>]
- Node-
Selects the check results that match this parameter value. This parameter specifies the node whose status is being displayed.
[-check-type <Type of AutoSupport Check>]
- AutoSupport Check Type-
Selects the check results that match this parameter value. This parameter specifies the type of AutoSupport check being performed.
[-status {ok|warning|failed|not-run}]
- Status of the Check-
Selects the check results that match this parameter value. This parameter specifies the result of this AutoSupport check.
[-error-detail <text>]
- Detailed Description of Error-
Selects the check results that match this parameter value. This parameter specifies the detailed error message for this AutoSupport check.
[-corrective-action <text>]
- Corrective Action-
Selects the check results that match this parameter value. This parameter specifies a description of how to correct any errors seen as part of this AutoSupport Check
The following example displays the detailed status of the AutoSupport subsystem for a node named node2:
cluster1::> system node autosupport check show-details -node node2
Node: node2 Category: http-https Component: http-put-destination Status: ok Detail: Successfully connected to "support.netapp.com/put". Component: http-post-destination Status: ok Detail: Successfully connected to "support.netapp.com/post". Category: smtp Component: mail-server Status: ok Detail: Successfully connected to "mailhost.netapp.com". Component: mail-server Status: ok Detail: Successfully connected to "sendmail.domain.com". Component: mail-server Status: ok Detail: Successfully connected to "qmail.domain.com". Category: on-demand Component: ondemand-server Status: ok Detail: Successfully connected to "support.netapp.com/aods". Category: configuration Component: configuration Status: ok Detail: No configuration issues found.
