system node autosupport check show-details
Display detailed status of AutoSupport subsystem
The system node autosupport check show-details command displays the detailed status of the AutoSupport subsystem. This includes verifying connectivity to your vendor's AutoSupport destinations by sending test messages and providing a list of possible errors in your AutoSupport configuration settings.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node-
Selects the check results that match this parameter value. This parameter specifies the node whose status is being displayed.
[-check-type <Type of AutoSupport Check>]- AutoSupport Check Type-
Selects the check results that match this parameter value. This parameter specifies the type of AutoSupport check being performed.
[-status {ok|warning|failed|not-run}]- Status of the Check-
Selects the check results that match this parameter value. This parameter specifies the result of this AutoSupport check.
[-error-detail <text>]- Detailed Description of Error-
Selects the check results that match this parameter value. This parameter specifies the detailed error message for this AutoSupport check.
[-corrective-action <text>]- Corrective Action-
Selects the check results that match this parameter value. This parameter specifies a description of how to correct any errors seen as part of this AutoSupport Check
The following example displays the detailed status of the AutoSupport subsystem for a node named node2:
cluster1::> system node autosupport check show-details -node node2
Node: node2
Category: https
Component: https-put-destination
Status: ok
Detail: Successfully connected to "support.netapp.com/put".
Component: https-post-destination
Status: ok
Detail: Successfully connected to "support.netapp.com/post".
Category: smtp
Component: mail-server
Status: ok
Detail: Successfully connected to "mailhost.netapp.com".
Status: ok
Detail: Successfully connected to "sendmail.domain.com".
Status: ok
Detail: Successfully connected to "qmail.domain.com".
Category: on-demand
Component: ondemand-server
Status: ok
Detail: Successfully connected to "support.netapp.com/aods".
Category: configuration
Component: configuration
Status: ok
Detail: No configuration issues found.
