system ha interconnect ood status show
Display the high-availability interconnect device out-of-order delivery (OOD) information
The system ha interconnect ood status show command displays configuration information of the out-of-order delivery-capable high-availability interconnect devices. This command is supported only on FAS2500 series nodes in the cluster.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}]- Node (privilege: advanced)-
Use this parameter to display all the fields from the specified node in the cluster.
[-is-ood-enabled {true|false}]- Is OOD Enabled (privilege: advanced)-
Selects the nodes that match this parameter value.
[-is-coalescing-enabled {true|false}]- Is Coalescing Enabled (privilege: advanced)-
The following example displays the HA interconnect device out-of-order delivery configuration information on FAS2500 series nodes in the cluster.
cluster1::*> system ha interconnect ood status show
Node: ic-f2554-03
NIC Used: 0
Is OOD Enabled: true
Is Coalescing Enabled: true
Node: ic-f2554-04
NIC Used: 0
2 entries were displayed.
