storage dqp show
Display Disk Qualification Package details
The storage dqp show command displays information about the Disk Qualification Package (DQP). The command displays the following information:
Node Name
Package Date
File Version
File Name
Drive Record Count
Drive Alias Record Count
Device Class Record Count
System Class Record Count
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Displays DQP information on the specified node.
[-package-date <text>]- Package Date-
Selects DQP information with the specified package date.
[-file-version <text>]- File Version-
Selects DQP information with the specified file version.
[-filename <text>]- File Name-
Selects DQP information with the specified file name.
[-drive-records <integer>]- Drive Record Count-
Selects DQP information with the specified drive record count.
[-alias-records <integer>]- Alias Record Count-
Selects DQP information with the specified drive alias record count.
[-device-records <integer>]- Device Record Count-
Selects DQP information with the specified device class record count.
[-system-records <integer>]- System Record Count-
Selects DQP information with the specified system class record count.
The following example displays the brief version of Disk Qualification Package details:
cluster1::> storage dqp show
Node Package Date Version
cluster1-01 20180907 3.17
cluster1-02 20180907 3.17
2 entries were displayed.
The following example displays the -instance version of Disk Qualification Package details:
cluster1::> storage dqp show -instance
Node: cluster1-01
Package Date: 20180907
Version: 3.17
File Name: qual_devices_v3
Drive Record Count: 626
Alias Record Count: 196
Device Record Count: 28
System Record Count: 3
Node: cluster1-02
Version: 3.17
