storage dqp show
Display Disk Qualification Package details
The storage dqp show
command displays information about the Disk Qualification Package (DQP). The command displays the following information:
Node Name
Package Date
File Version
File Name
Drive Record Count
Drive Alias Record Count
Device Class Record Count
System Class Record Count
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Displays DQP information on the specified node.
[-package-date <text>]
- Package Date-
Selects DQP information with the specified package date.
[-file-version <text>]
- File Version-
Selects DQP information with the specified file version.
[-filename <text>]
- File Name-
Selects DQP information with the specified file name.
[-drive-records <integer>]
- Drive Record Count-
Selects DQP information with the specified drive record count.
[-alias-records <integer>]
- Alias Record Count-
Selects DQP information with the specified drive alias record count.
[-device-records <integer>]
- Device Record Count-
Selects DQP information with the specified device class record count.
[-system-records <integer>]
- System Record Count-
Selects DQP information with the specified system class record count.
The following example displays the brief version of Disk Qualification Package details:
cluster1::> storage dqp show Node Package Date Version ---------------- ---------------- --------- cluster1-01 20180907 3.17 cluster1-02 20180907 3.17 2 entries were displayed.
The following example displays the -instance version of Disk Qualification Package details:
cluster1::> storage dqp show -instance Node: cluster1-01 Package Date: 20180907 Version: 3.17 File Name: qual_devices_v3 Drive Record Count: 626 Alias Record Count: 196 Device Record Count: 28 System Record Count: 3 Node: cluster1-02 Package Date: 20180907 Version: 3.17 File Name: qual_devices_v3 Drive Record Count: 626 Alias Record Count: 196 Device Record Count: 28 System Record Count: 3 2 entries were displayed.
