storage dqp show
Display Disk Qualification Package details
The storage dqp show command displays information about the Disk Qualification Package (DQP). The command displays the following information:
Node Name
Package Date
File Version
File Name
Drive Record Count
Drive Alias Record Count
Device Class Record Count
System Class Record Count
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Displays DQP information on the specified node.
- [-package-date <text>]- Package Date
Selects DQP information with the specified package date.
- [-file-version <text>]- File Version
Selects DQP information with the specified file version.
- [-filename <text>]- File Name
Selects DQP information with the specified file name.
- [-drive-records <integer>]- Drive Record Count
Selects DQP information with the specified drive record count.
- [-alias-records <integer>]- Alias Record Count
Selects DQP information with the specified drive alias record count.
- [-device-records <integer>]- Device Record Count
Selects DQP information with the specified device class record count.
- [-system-records <integer>]- System Record Count
Selects DQP information with the specified system class record count.
The following example displays the brief version of Disk Qualification Package details:
cluster1::> storage dqp show
    Node             Package Date     Version
    cluster1-01   20180907         3.17
    cluster1-02   20180907         3.17
    2 entries were displayed.
The following example displays the -instance version of Disk Qualification Package details:
cluster1::> storage dqp show -instance
Node: cluster1-01
          Package Date: 20180907
               Version: 3.17
             File Name: qual_devices_v3
          Drive Record Count: 626
          Alias Record Count: 196
         Device Record Count: 28
         System Record Count: 3
Node: cluster1-02
                                       Version: 3.17
 PDFs
PDFs
