Command reference
storage dqp show
Display Disk Qualification Package details
The storage dqp show command displays information about the Disk Qualification Package (DQP). The command displays the following information:
  • Node Name
  • Package Date
  • File Version
  • File Name
  • Drive Record Count
  • Drive Alias Record Count
  • Device Class Record Count
  • System Class Record Count
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Displays DQP information on the specified node.
[-package-date <text>] - Package Date
Selects DQP information with the specified package date.
[-file-version <text>] - File Version
Selects DQP information with the specified file version.
[-filename <text>] - File Name
Selects DQP information with the specified file name.
[-drive-records <integer>] - Drive Record Count
Selects DQP information with the specified drive record count.
[-alias-records <integer>] - Alias Record Count
Selects DQP information with the specified drive alias record count.
[-device-records <integer>] - Device Record Count
Selects DQP information with the specified device class record count.
[-system-records <integer>] - System Record Count
Selects DQP information with the specified system class record count.
The following example displays the brief version of Disk Qualification Package details:
cluster1::> storage dqp show
    Node             Package Date     Version
    cluster1-01   20180907         3.17
    cluster1-02   20180907         3.17
    2 entries were displayed.
The following example displays the -instance version of Disk Qualification Package details:
cluster1::> storage dqp show -instance
Node: cluster1-01
          Package Date: 20180907
               Version: 3.17
             File Name: qual_devices_v3
          Drive Record Count: 626
          Alias Record Count: 196
         Device Record Count: 28
         System Record Count: 3
Node: cluster1-02
                                       Version: 3.17
