storage dqp show
PDF of this doc site
Creating your file...
Display Disk Qualification Package details
The storage dqp show
command displays information about the Disk Qualification Package (DQP). The command displays the following information:
Node Name
Package Date
File Version
File Name
Drive Record Count
Drive Alias Record Count
Device Class Record Count
System Class Record Count
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Displays DQP information on the specified node.
[-package-date <text>]
- Package Date-
Selects DQP information with the specified package date.
[-file-version <text>]
- File Version-
Selects DQP information with the specified file version.
[-filename <text>]
- File Name-
Selects DQP information with the specified file name.
[-drive-records <integer>]
- Drive Record Count-
Selects DQP information with the specified drive record count.
[-alias-records <integer>]
- Alias Record Count-
Selects DQP information with the specified drive alias record count.
[-device-records <integer>]
- Device Record Count-
Selects DQP information with the specified device class record count.
[-system-records <integer>]
- System Record Count-
Selects DQP information with the specified system class record count.
The following example displays the brief version of Disk Qualification Package details:
cluster1::> storage dqp show Node Package Date Version ---------------- ---------------- --------- cluster1-01 20180907 3.17 cluster1-02 20180907 3.17 2 entries were displayed.
The following example displays the -instance version of Disk Qualification Package details:
cluster1::> storage dqp show -instance Node: cluster1-01 Package Date: 20180907 Version: 3.17 File Name: qual_devices_v3 Drive Record Count: 626 Alias Record Count: 196 Device Record Count: 28 System Record Count: 3 Node: cluster1-02 Package Date: 20180907 Version: 3.17 File Name: qual_devices_v3 Drive Record Count: 626 Alias Record Count: 196 Device Record Count: 28 System Record Count: 3 2 entries were displayed.
