system node coredump show
Display a list of coredumps
The system node coredump show command displays basic information about core dumps, such as the core dump name, time of panic that triggered the core dump and whether the core file is saved. You can specify optional parameters to display information that matches only those parameters. For example, to display the list of kernel core files, run the command with -type kernel.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-system ]
If you specify this parameter, the command displays the following information: -
Node name
Core dump name
Core dump ID
Node that panicked and generated the core
System ID of the node that panicked and generated the core
Version of the core
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node That Owns the Coredump
If you specify both this parameter and the -corenameparameter, the command displays detailed information about the specified core. If you specify this parameter by itself, the command displays information about the core files on the specified node.
- [-type {kernel|ancillary-kernel-segment|application}]- Coredump Type
This parameter specifies the type of core files to be displayed. If the type is kernel and the system supports segmented core files, the command displays information about primary kernel core segment files. If the type is kernel and the system does not support segmented core files, the command displays information about full core files. If the type is ancillary-kernel-segment, the command displays information about ancillary kernel core segment files. If the type is application, the command displays information about application core files. If no type is specified, the command displays information about core files of type kernel or application.
- [-corename <text>]- Coredump Name
If you specify both this parameter and the -nodeparameter, the command displays detailed information about the specified core. If you specify this parameter by itself, the command displays information about the core files that match the specified name.
- [-panic-node <text>]- Node That Generated Core
If you specify this parameter with a node name, the command displays information only about the core files that were generated when the specified node panicked.
- [-panic-systemid <integer>]- System ID of Node That Generated Core
If you specify this parameter, the command displays information only about the core files that were generated when the node with the specified system ID panicked.
- [-version <text>]- Data ONTAP Version of Core
If you specify this parameter, the command displays information only about the core files that match the specified version.
- [-panic-time <MM/DD/YYYY HH:MM:SS>]- Time of Panic That Generated Core
If you specify this parameter, the command displays information only about the core files that were generated by a panic at the specified time. Specify time in the format of MM/DD/YYYY HH:MM:SS [- HH:MM]_`` . You can use ``_[- HH:MM]to specify the time range within which all core files triggered by a panic are displayed.[+- HH:MM]is relative to UTC.
- [-panic-string <text>]- Panic String
If you specify this parameter, the command displays information only about the core files that match the specified panic string.
- [-is-saved {true|false}]- Saved Core
If you specify this parameter, the command displays information only about the core dumps that are or are not saved yet to a core file.
- [-is-partial {true|false}]- Partial Core
If you specify this parameter, the command displays information only about the core dumps that are or are not partially saved.
- [-save-attempts <integer>]- Number of Attempts to Save Core
If you specify this parameter, the command displays information only about the core dumps that have the specified number of successful or failed save attempts.
- [-space-needed {<integer>[KB|MB|GB|TB|PB]}]- Space Needed To Save Core
If you specify this parameter, the command displays information only about the core dumps that need the specified amount of disk space to save into a core file.
- [-size <text>]- Size of Core (bytes)
If you specify this parameter, the command displays information only about the saved core files that are of the specified size.
- [-md5-data-chksum <text>]- MD5 Checksum of the Compressed Data of Core
If you specify this parameter, the command displays information only about the saved core files that have the specified MD5 checksum for compressed data of the core.
- [-ancillary-segment-directory <text>]- Directory Holding Ancillary Kernel Core Segments
If you specify this parameter, the command displays information only about the saved core files that have the specified ancillary segment directory.
The following examples display information about the core files:
cluster1::> system node coredump show
Node   Core Name                  Saved  Panic Time
node0
     core.101182345.2010-02-01.14_19_08.nz    false  2/1/2010 09:19:08
       Partial Core: false
       Number of Attempts to Save Core: 2
       Space Needed To Save Core: 4.45GB
node1
     core.101268397.2010-05-30.19_37_31.nz    true  5/30/2010 15:37:31
node2
     core.101270930.2010-09-06.18_40_03.nz    true  9/6/2010 14:40:03
node3
     core.101271326.2010-09-06.19_06_18.nz    true  9/6/2010 15:06:18
     core.101271326.2010-09-06.19_09_49.nz    true  9/6/2010 15:09:49
4 entries were displayed.
cluster1::> system node coredump show -panic-time 9/6/2010 15:00:00+3:00
node3
2 entries were displayed.
 PDFs
PDFs
