ONTAP commands
system controller flash-cache secure-erase show
Display the Flash Cache card status
The system controller flash-cache secure-erase show command displays the current Flash Cache device secure-erase status.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is specified, only status information for the matching node is displayed.
[-device-id <integer>] - Device Id
If this parameter is specified, only status information for the matching device-id is displayed.
[-device-state {ok|erasing|erased|failed|removed}] - Device State
If this parameter is specified, only status information for the matching device-state is displayed.
The following example displays the current state of all the Flash Cache devices:
cluster1::> system controller flash-cache secure-erase show
Node      Device ID Slot Device State
node1
                  0 6-1  ok
                  1 6-2  erasing
node2
                  0 6-1  erased
                  1 6-2  ok
4 entries were displayed.
