vserver nvme namespace show
Display NVMe namespaces
The vserver nvme namespace show command displays information for NVMe namespaces.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display the NVMe namespaces that match the Vserver that you specify.
- [-path <path>]- Namespace Path
Use this parameter to display the NVMe namespace that matches the path that you specify.
- [-size {<integer>[KB|MB|GB|TB|PB]}]- Size
Use this parameter to display the NVMe namespaces that match the size that you specify.
- [-size-used {<integer>[KB|MB|GB|TB|PB]}]- Size Used
Use this parameter to display the NVMe namespaces that match this parameter value.
- [-ostype {aix|linux|vmware|windows}]- OS Type
- [-comment <text>]- Comment
- [-block-size {512|4KB}]- Block Size
- [-state {online|offline|nvfail|space-error}]- State
- [-is-read-only {true|false}]- Is Read Only
- [-creation-timestamp <MM/DD/YYYY HH:MM:SS>]- Creation Time
- [-uuid <UUID>]- Namespace UUID
- [-restore-inaccessible {true|false}]- Restore Inaccessible
- [-node <nodename>]- Node Hosting the Namespace
- [-volume <volume name>]- Volume Name
- [-qtree <qtree name>]- Qtree Name
- [-subsystem <text>]- Mapped Subsystem
Use this parameter to display the NVMe namespaces that are attached to a Subsystem that matches this parameter value.
- [-nsid <Hex 32bit Integer>]- Namespace ID
- [-anagrpid <Hex 32bit Integer>]- ANA Group ID (privilege: advanced)
Use this parameter to display the NVMe namespaces that match Asymmetric Namespace Access (ANA) group identifier that you specify.
- [-vserver-id <integer>]- Vserver ID
- [-container-state {online|aggregate-offline|volume-offline|error}]- Namespace Container State (privilege: advanced)
Selects the namespaces that match this parameter value. The container states are: -
online- The namespace's aggregate and volume are online.
aggregate-offline- The namespace's aggregate is offline.
volume-offline- The namespace's volume is offline.
error- An error occurred accessing the namespace's volume.
- [-include-offline-containers <true>]- Include Namespaces on Offline Volumes and Aggregates (privilege: advanced)
If true, include available information for namespaces in offline aggregates and offline volumes in the output. By default, namespaces in offline aggregates and offline volumes are excluded from the output.
- [-application <text>]- Application
Selects the namespace that are part of an application that matches the parameter value.
cluster::*> vserver nvme namespace show -vserver vs1 Vserver Path State Size Subsystem NSID --------- ------------------------------- ------- ------ ---------- --------- vs1 /vol/test_1_vol/ns1 online 10GB subsys1 00000001h vs1 /vol/test_1_vol/ns2 online 500MB subsys1 00000002h vs1 /vol/test_1_vol/ns3 online 1TB - - 3 entries were displayed.
 PDFs
PDFs
