vserver nvme namespace show
Display NVMe namespaces
The vserver nvme namespace show command displays information for NVMe namespaces.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe namespaces that match the Vserver that you specify.
[-path <path>] - Namespace Path
Use this parameter to display the NVMe namespace that matches the path that you specify.
[-size {<integer>[KB|MB|GB|TB|PB]}] - Size
Use this parameter to display the NVMe namespaces that match the size that you specify.
[-size-used {<integer>[KB|MB|GB|TB|PB]}] - Size Used
Use this parameter to display the NVMe namespaces that match this parameter value.
[-ostype {aix|linux|vmware|windows}] - OS Type
[-comment <text>] - Comment
[-block-size {512|4KB}] - Block Size
[-state {online|offline|nvfail|space-error}] - State
[-is-read-only {true|false}] - Is Read Only
[-creation-timestamp <MM/DD/YYYY HH:MM:SS>] - Creation Time
[-uuid <UUID>] - Namespace UUID
[-restore-inaccessible {true|false}] - Restore Inaccessible
[-node <nodename>] - Node Hosting the Namespace
[-volume <volume name>] - Volume Name
[-qtree <qtree name>] - Qtree Name
[-subsystem <text>] - Mapped Subsystem
Use this parameter to display the NVMe namespaces that are attached to a Subsystem that matches this parameter value.
[-nsid <Hex 32bit Integer>] - Namespace ID
[-anagrpid <Hex 32bit Integer>] - ANA Group ID (privilege: advanced)
Use this parameter to display the NVMe namespaces that match Asymmetric Namespace Access (ANA) group identifier that you specify.
[-vserver-id <integer>] - Vserver ID
[-container-state {online|aggregate-offline|volume-offline|error}] - Namespace Container State (privilege: advanced)
Selects the namespaces that match this parameter value. The container states are:
  • online - The namespace's aggregate and volume are online.
  • aggregate-offline - The namespace's aggregate is offline.
  • volume-offline - The namespace's volume is offline.
  • error - An error occurred accessing the namespace's volume.
[-include-offline-containers <true>] - Include Namespaces on Offline Volumes and Aggregates (privilege: advanced)
If true, include available information for namespaces in offline aggregates and offline volumes in the output. By default, namespaces in offline aggregates and offline volumes are excluded from the output.
[-application <text>] - Application
Selects the namespace that are part of an application that matches the parameter value.
cluster::*> vserver nvme namespace show -vserver vs1
Vserver   Path                            State     Size Subsystem       NSID
vs1       /vol/test_1_vol/ns1             online    10GB subsys1    00000001h
vs1       /vol/test_1_vol/ns2             online   500MB subsys1    00000002h
vs1       /vol/test_1_vol/ns3             online     1TB -                  -
3 entries were displayed.
