vserver nvme namespace show
Display NVMe namespaces
The vserver nvme namespace show command displays information for NVMe namespaces.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects the NVMe namespaces that match the Vserver that you specify.
[-path <path>]- Namespace Path-
Selects the NVMe namespaces that match the path that you specify.
[-size {<integer>[KB|MB|GB|TB|PB]}]- Size-
Selects the NVMe namespaces that match the size that you specify.
[-size-used {<integer>[KB|MB|GB|TB|PB]}]- Size Used-
Selects the NVMe namespaces that match this parameter value.
[-ostype {aix|linux|vmware|windows}]- OS Type-
[-comment <text>]- Comment-
[-block-size {512|4KB}]- Block Size-
[-state {online|offline|nvfail|space-error}]- State-
[-is-read-only {true|false}]- Is Read Only-
[-creation-timestamp <MM/DD/YYYY HH:MM:SS>]- Creation Time-
[-uuid <UUID>]- Namespace UUID-
[-restore-inaccessible {true|false}]- Restore Inaccessible-
[-node <nodename>]- Node Hosting the Namespace-
[-volume <volume name>]- Volume Name-
[-qtree <qtree name>]- Qtree Name-
[-nsid <Hex 32bit Integer>]- Namespace ID-
[-anagrpid <Hex 32bit Integer>]- ANA Group ID (privilege: advanced)-
Selects the NVMe namespaces that match Asymmetric Namespace Access (ANA) group identifier that you specify.
[-vserver-id <integer>]- Vserver ID-
[-container-state {online|aggregate-offline|volume-offline|error}]- Namespace Container State (privilege: advanced)-
Selects the namespaces that match this parameter value. The container states are:
online- The namespace's aggregate and volume are online. -
aggregate-offline- The namespace's aggregate is offline. -
volume-offline- The namespace's volume is offline. -
error- An error occurred accessing the namespace's volume.
[-include-offline-containers <true>]- Include Namespaces on Offline Volumes and Aggregates (privilege: advanced)-
If true, include available information for namespaces in offline aggregates and offline volumes in the output. By default, namespaces in offline aggregates and offline volumes are excluded from the output.
[-zrto-vol-consensus {true|false}]- ZRTO Volume Consensus-
Selects the namespaces that match the specified value. The status indicates whether the volume containing the namespace in a SnapMirror Synchronous relationship can process operations.
[-application <text>]- Application-
Selects the namespaces that are part of an application that matches the parameter value.
[-consistency-group <text>]- Consistency Group Name-
Selects the namespaces that are associated with the specified consistency group.
cluster::*> vserver nvme namespace show -vserver vs1 Vserver Path State Size Subsystem NSID --------- ------------------------------- ------- ------ ---------- --------- vs1 /vol/test_1_vol/ns1 online 10GB subsys1 00000001h vs1 /vol/test_1_vol/ns2 online 500MB subsys1 00000002h vs1 /vol/test_1_vol/ns3 online 1TB - - 3 entries were displayed.
