network interface lif-weights show
Show the load-balancer LIF weights
The network interface lif-weights show command displays the weights assigned to each LIF in a DNS load-balancing zone in a Vserver.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver (privilege: advanced)-
Use this parameter to display information only for the specified Vservers.
[-zone <text>]- DNS Zone (privilege: advanced)-
Use this parameter to display information only for the specified DNS zones.
[-address <IP Address>]- Network Address (privilege: advanced)-
Use this parameter to display information only for the specified IP addresses.
[-weight <double>]- Load Balancer Weight (privilege: advanced)-
Use this parameter to display information only for the specified load balancer weights
The following example displays LIF weights for vserver "vs1".
cluster1::> network interface lif-weights show -vserver vs1
Network
Vserver DNS Zone Address Weight
vs1
a.com 4.4.4.4 12.4206
x.com 1.1.1.1 12.4206
x.com 10.72.46.236 12.4206
3 entries were displayed.
