network interface lif-weights show
Show the load-balancer LIF weights
The network interface lif-weights show command displays the weights assigned to each LIF in a DNS load-balancing zone in a Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver (privilege: advanced)
Use this parameter to display information only for the specified Vservers.
- [-zone <text>]- DNS Zone (privilege: advanced)
Use this parameter to display information only for the specified DNS zones.
- [-address <IP Address>]- Network Address (privilege: advanced)
Use this parameter to display information only for the specified IP addresses.
- [-weight <double>]- Load Balancer Weight (privilege: advanced)
Use this parameter to display information only for the specified load balancer weights
The following example displays LIF weights for vserver "vs1".
cluster1::> network interface lif-weights show -vserver vs1
                               Network
Vserver    DNS Zone            Address        Weight
vs1
           a.com               4.4.4.4       12.4206
           x.com               1.1.1.1       12.4206
           x.com               10.72.46.236  12.4206
3 entries were displayed.
 PDFs
PDFs
