network interface lif-weights show
Show the load-balancer LIF weights
The network interface lif-weights show command displays the weights assigned to each LIF in a DNS load-balancing zone in a Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver
Use this parameter to display information only for the specified Vservers.
[-zone <text>] - DNS Zone
Use this parameter to display information only for the specified DNS zones.
[-address <IP Address>] - Network Address
Use this parameter to display information only for the specified IP addresses.
[-weight <double>] - Load Balancer Weight
Use this parameter to display information only for the specified load balancer weights
The following example displays LIF weights for vserver "vs1".
cluster1::> network interface lif-weights show -vserver vs1
                               Network
Vserver    DNS Zone            Address        Weight
vs1
           a.com               4.4.4.4       12.4206
           x.com               1.1.1.1       12.4206
           x.com               10.72.46.236  12.4206
3 entries were displayed.
