snapmirror mediator remove
Remove mediator config entry
The snapmirror mediator remove command deletes a mediator configuration entry.
-peer-cluster <text>- Peer cluster-
Peer cluster with AutomatedFailOver SnapMirror relationships.
[-type {on-prem|cloud}]- Mediator Type-
Specifies the type of the mediator. The value
on-premrepresents ONTAP Mediator. The valuecloudrepresents ONTAP cloud mediator. The default value ison-prem. [-mediator-address <IP Address>]- Mediator Ip Address-
Specifies the IP address of the mediator. This is only applicable for ONTAP Mediator.
[-f, -force <true>]- Force (privilege: advanced)-
The force option deletes the local configuration even if the peer cluster or mediator is not reachable.
The following example removes a mediator configuration entry for ONTAP Mediator.
clusA::> snapmirror mediator remove -peer-cluster clusB -mediator-address 10.140.102.227 Info: [Job 36] 'mediator remove' job queued
The following example removes a mediator configuration entry for ONTAP cloud mediator.
clusA::> snapmirror mediator remove -peer-cluster clusB -type cloud Info: [Job 53] 'mediator remove' job queued
