snapmirror mediator remove
Remove mediator config entry
The snapmirror mediator remove command deletes a mediator configuration entry.
-mediator-address <IP Address>- Mediator Ip Address-
Specifies the IP address of the mediator.
-peer-cluster <text>- Peer cluster-
Peer cluster with AutomatedFailOver SnapMirror relationships.
The following example removes a mediator configuration entry.
clusA::> snapmirror mediator remove -mediator-address 10.140.102.227 -peer-cluster clusB Info: [Job 36] 'mediator remove' job queued
