Command reference
snapmirror mediator remove
Remove mediator config entry
The snapmirror mediator remove command deletes a mediator configuration entry.
-peer-cluster <text> - Peer cluster
Peer cluster with AutomatedFailOver SnapMirror relationships.
[-type {on-prem|cloud}] - Mediator Type
Specifies the type of the mediator. The value on-prem represents ONTAP Mediator. The value cloud represents ONTAP cloud mediator. The default value is on-prem .
[-mediator-address <IP Address>] - Mediator Ip Address
Specifies the IP address of the mediator. This is only applicable for ONTAP Mediator.
[-f, -force <true>] - Force (privilege: advanced)
The force option deletes the local configuration even if the peer cluster or mediator is not reachable.
The following example removes a mediator configuration entry for ONTAP Mediator.
clusA::> snapmirror mediator remove -peer-cluster clusB -mediator-address 10.140.102.227
Info: [Job 36] 'mediator remove' job queued
The following example removes a mediator configuration entry for ONTAP cloud mediator.
clusA::> snapmirror mediator remove -peer-cluster clusB -type cloud
Info: [Job 53] 'mediator remove' job queued
