metrocluster vserver show
Display MetroCluster Vserver relationships
The metrocluster vserver show command displays configuration information for all pairs of Vservers in MetroCluster.
[-fields <fieldname>,…] -
The command output includes the specified field or fields
[-creation-time ](privilege: advanced) -
Shows the last configuration modification time on the Vserver
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cluster <Cluster name>]- Cluster Name-
Name of the cluster where the Vserver belongs
[-vserver <vserver>]- Vserver-
Name of the Vserver
[-partner-vserver <vserver>]- Partner Vserver-
Name of the partner Vserver
[-configuration-state {healthy|unhealthy|degraded|pending-setup|syncing|replication-paused|pending-switchback}]- Configuration State-
Configuration states include:
healthy -
unhealthy -
degradedindicates that Vservers are not in sync -
syncingindicates that the Vserver configuration is being synchronized -
replication-pausedindicates that the configuration replication was manually paused -
pending-setupindicates that partner Vserver creation is pending
[-corrective-action <text>]- Corrective Action-
Corrective action which can be followed to successfully create the partner Vserver
[-creation-time-of-last-applied-change <MM/DD/YYYY HH:MM:SS>]- Creation Time on the Source-
Last configuration modification time on the Vserver
[-failed-row <smdb-row-op>]- Failed Row-
Failed replication row
[-failed-object <text>]- Failed Object-
Displays the failed object name
[-failed-reason <text>]- Failed Replication Reason-
Failed replication reason
[-out-of-sync <true>]- Is Out of Sync-
Indicates that the Vserver configuration replication is not in sync
[-config-resume-time <MM/DD/YYYY HH:MM:SS>]- Configuration Resume Time-
Displays the resume time of the Vserver configuration replication
[-irrecoverable-apply-failed-reason <text>]- Reason for Failure-
Reason for the replication failure
The following example shows the output of the command when partner Vservers are created
clusA::> metrocluster vserver show
Cluster: clusA
Partner Configuration
Vserver Vserver State
clusA clusB healthy
vs1 vs1-mc healthy
Cluster: clusB
clusB clusA healthy
3 entries were displayed.
The following example shows the output of the command when the partner Vserver creation is pending
Cluster: clusA
clusA clusB healthy
vs1 - pending-setup
Corrective Action: Create Ipspace ips1 on the partner cluster.
2 entries were displayed.
