Command reference
system switch ethernet log modify
Modify the Ethernet switch log request.
The system switch ethernet log modify command modifies the the enablement and status of the hourly collection of periodic data and the status of the collection of detailed support logs.
-device <text> - Switch Name
Ethernet switch device for which the log request is being made.
Note The device must be one of the devices listed as an Ethernet switch from the system switch ethernet show command. The full device name from the system switch ethernet show command must be used.
[-support-requested {true|false}] - Support Log Requested
Request (true) or cancel (false) support log collection.
[-periodic-enabled {true|false}] - Periodic Log Enabled
Enable (true) or disable (false) periodic log collection.
cluster1::> system switch ethernet log modify -device cs1 -periodic-enabled true
Enables periodic log collection for the specified Ethernet switch.
