Command reference
vserver nvme subsystem host add
Add a host to a subsystem
The vserver nvme subsystem host add command adds an NVMe host to an NVMe subsystem on a Vserver.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-subsystem <text> - Subsystem
Specifies the NVMe target subsystem.
-host-nqn <text> - Host NQN
Specifies the NVMe subsystem host NQN.
[-priority {regular|high}] - Host priority
Specifies the host priority.
[-dhchap-host-secret-key <text>] - Authentication Host Secret
Specifies the NVMe DH-HMAC-CHAP in-band authentication host secret.
[-dhchap-controller-secret-key <text>] - Authentication Controller Secret
Specifies the NVMe DH-HMAC-CHAP in-band authentication controller secret.
[-dhchap-hash-function {sha-256|sha-512}] - Authentication Hash Function
Specifies the NVMe DH-HMAC-CHAP in-band authentication hash function.
[-dhchap-dh-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}] - Authentication Diffie-Hellman Group
Specifies the NVMe DH-HMAC-CHAP in-band authentication Diffie-Hellman group size.
{ [-tls-configured-psk <text>] - TLS Configured PSK
Specifies the configured pre-shared key (PSK) for the host.
| [-tls-generated-psk <true>] - Use a Generated PSK }
Set this field to true to configure TLS authentication using a generated pre-shared key (PSK).
NOTE:
  • The -dhchap-host-secret-key is required when -tls-generated-psk is set true .
  • The -dhchap-dh-group should not be set to None .
  • If the -dhchap-dh-group is not provided, then DH group size of 2048-bit is considered by default.
[-proximal-vservers <text>,…​] - Proximal Vserver Names
Select Vservers configured as proximal to the specified host.
cluster::*> vserver nvme subsystem host add -vserver vs1 -subsystem ss1 -host-nqn nqn.2001-01.com.example:nvme-host1 -proximal-vservers vs1
Adds a host with the specified NQN to the NVMe subsystem ss1 on Vserver vs1 that is proximal to Vserver vs1 .
cluster::*> vserver nvme subsystem host add -vserver vs1 -subsystem ss1 -host-nqn nqn.2001-01.com.example:nvme-host1 -dhchap-host-secret-key DHHC-1:00:9EOar0LpPQbWqQbrQuhN4oYtFXsX0S5VXyJjrxrX8FYzGJe0 -dhchap-dh-group 2048-bit -tls-generated-psk
Adds a host with the specified NQN to the NVMe subsystem ss1 on Vserver vs1 , configuring TLS authentication using a generated pre-shared key (PSK).
