vserver nvme subsystem host add
Add a host to a subsystem
The vserver nvme subsystem host add
command adds an FC-NVMe host to an NVMe subsystem on a Vserver.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-subsystem <text>
- Subsystem-
Specifies the NVMe target subsystem.
-host-nqn <text>
- Host NQN-
Specifies the NVMe subsystem host NQN.
[-priority {regular|high}]
- Host priority-
Specifies the Host priority.
[-dhchap-host-secret-key <text>]
- Authentication Host Secret-
Specifies the NVMe DH-HMAC-CHAP in-band authentication host secret.
[-dhchap-controller-secret-key <text>]
- Authentication Controller Secret-
Specifies the NVMe DH-HMAC-CHAP in-band authentication controller secret.
[-dhchap-hash-function {sha-256|sha-512}]
- Authentication Hash Function-
Specifies the NVMe DH-HMAC-CHAP in-band authentication hash function.
[-dhchap-dh-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}]
- Authentication Diffie-Hellman Group-
Specifies the NVMe DH-HMAC-CHAP in-band authentication Diffie-Hellman group size.
cluster::*> vserver nvme subsystem host add -vserver vs_1 -subsystem sub_1 -host-nqn nqn.2001-01.com.example:nvme-host1
Adds a host with the specified NQN to the NVMe subsystem sub_1
on Vserver vs_1
