network options send-soa modify
Modify Send SOA settings
This command sets the status of sending statement of authority record in the DNS response.
[-enable {true|false}]- Enable Sending SOA (privilege: advanced)-
Setting this parameter to
trueenables sending the statement of authority (SOA) record in the DNS response. Setting it tofalsedisables sending the statement of authority (SOA) record in the DNS response for the cluster.
The following example will enable the sending of statement of authority (SOA)
cluster1::> network options send-soa modify -enable true
The following example will disable the sending of statement of authority (SOA)
cluster1::> network options send-soa modify -enable false
