Command reference
vserver fcp show
Display FCP service configuration
Displays the current status of the FCP service in a cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the FCP services that match the Vserver that you specify.
[-target-name <text>] - Target Name
Use this parameter to display the FCP service that matches the target name that you specify.
[-status-admin {down|up}] - Administrative Status
Use this parameter to display the FCP services that match the administrative status that you specify.
cluster1::> vserver fcp show
                                       Status
server    Target Name                  Admin
s0        20:00:00:a0:98:0c:b0:eb      up
s2        20:01:00:a0:98:0c:b0:eb      up
 entries were displayed.
Displays the FCP configuration for all the Vservers in the cluster.
