vserver fcp show
Display FCP service configuration
Displays the current status of the FCP service in a cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the FCP services that match the Vserver that you specify.
[-target-name <text>]- Target Name-
Use this parameter to display the FCP service that matches the target name that you specify.
[-status-admin {down|up}]- Administrative Status-
Use this parameter to display the FCP services that match the administrative status that you specify.
cluster1::> vserver fcp show
Status
server Target Name Admin
s0 20:00:00:a0:98:0c:b0:eb up
s2 20:01:00:a0:98:0c:b0:eb up
entries were displayed.
Displays the FCP configuration for all the Vservers in the cluster.
