Command reference
qos policy-group modify
Modify a policy group
The qos policy-group modify command modifies a user-created policy group.
-policy-group <text> - Policy Group Name
Specifies the name of the policy group that you want to modify.
[-max-throughput <qos_tput>] - Maximum Throughput
Specifies the maximum throughput for the policy group. A maximum throughput limit specifies the throughput that the policy group must not exceed. It is specified in terms of IOPS or MB/s, or a combination of comma separated IOPS and MB/s. The range is one to infinity. A value of zero is accepted but is internally treated as infinity.
The values entered here are case-insensitive, and the units are base ten. There should be no space between the number and the units. The default value for max-throughput is infinity, which can be specified by the special value "INF". Note there is no default unit - all numbers except zero require explicit specification of the units.
Two reserved keywords, "none" and "INF", are available for the situation that requires removal of a value, and the situation that needs to specify the maximum available value.
Examples of valid throughput specifications are: "100B/s", "10KB/s", "1gb/s", "500MB/s", "1tb/s", and "100iops".
[-min-throughput <qos_tput>] - Minimum Throughput
Specifies the minimum throughput for the policy group. A minimum throughput specifies the desired performance level for a policy group. It is specified in terms of IOPS or MB/s, or a combination of comma separated IOPS and MB/s.
The values entered here are case-insensitive, and the units are base ten. There should be no space between the number and the units. The default value for min-throughput is "0". The default unit is IOPS.
One reserved keyword, 'none' is available for the situation that requires removal of a value.
Examples of valid throughput specifications are: "100B/s", "10KB/s", "1gb/s", "500MB/s", "1tb/s", "100iops", "100iops,400KB/s", and "800KB/s,100iops"
{ [-burst-percent <integer>] - Throughput burst percent
Specifies the percentage over the effective limit a policy group may process requests using accumulated credit. This is mutually exclusive with burst-iops The default burst-percent is "50".
| [-burst-iops <integer>] - Throughput burst IOPS Maximum }
Specifies the IOPS effective limit a policy group may process requests using accumulated credit. Compatible with limits expressed in IOPS or combination of IOPS and throughput. This is mutually exclusive with burst-percent. If burst-iops is less than max-throughput, then max-throughput is used.
[-burst-duration <integer>] - Throughput burst duration (sec)
Specifies the time in seconds a policy-group may burst over the effective limit. The default burst-duration is "1".
cluster1::> qos policy-group modify p1 -max-throughput 10IOPS
Modifies the "p1" policy group and sets its max throughput value to 10 IOPS.
