Command reference
vserver cifs users-and-groups local-user modify
Modify a local user
The vserver cifs users-and-groups local-user modify command modifies attributes of a local user.
-vserver <vserver name> - Vserver
This specifies the name of the Vserver.
-user-name <CIFS name> - User Name
This specifies the user name.
[-full-name <TextNoCase>] - Full Name
This specifies the user's full name. If the full name contains a space in the name, enclose it within double quotation marks
[-description <TextNoCase>] - Description
This specifies a description for this local user. If the description contains a space, enclose the parameter in quotation marks.
[-is-account-disabled {true|false}] - Is Account Disabled
This specifies if the user account is enabled or disabled. Set this parameter to true to disable the account. Set this parameter to false to enable the account.
The following example modifies the full name of the local user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups local-user modify -user-name CIFS_SERVER\u1 -full-name "John Smith" -vserver vs1
