storage aggregate object-store config modify
Modify object store configuration attributes
The storage aggregate object-store config modify command is used to update one or more of object store configuration parameters. This command must not be used to reassociate an existing valid object-store configuration to a new object-store or container. The modifiable parameters include object store name, server name, port, access_key, secret-password, ipspace and is-ssl-enabled.
-object-store-name <text>- Object Store Configuration Name-
This parameter identifies the configuration to be modified.
[-new-object-store-name <text>]- Object Store Configuration New Name-
This optional parameter specifies the new name for the object store configuration.
[-auth-type <object_store_auth_type>]- Authentication Used to Access the Object Store-
This optional parameter specifies where the system obtains credentials for authentication to an object store. The available choices depend on the platform (Cloud Volumes ONTAP or not) and provider-type (AWS_S3 or not). The
keysvalue is always applicable, and if selected means that theaccess-keyandsecret-passwordare provided by the system administrator. In Cloud Volumes ONTAP, theEC2-IAMvalue is also applicable. It means that the IAM role is associated with the EC2 instance, and that theaccess-key,secret-passwordand session token are are retrieved from EC2 instance metadata for this IAM role. Note that-use-iam-roleand-auth-typeare mutually exclusive,-auth-type EC2-IAMis an equivalent of-use-iam-role true, and-auth-type keyis an equivalent of-use-iam-role false. In Cloud Volumes ONTAP, theGCP-SAvalue may also be applicable. It means that a session token is retrieved from the GCP instance metadata for the Service Account associated with the GCP instance. Similarly,Azure-MSImeans that a session token is retrieved from the Azure instance metadata for the Managed Service Identity (MSI) associated with the Azure instance. For theAWS_S3provider, theCAP(C2S Authentication Portal) value is also applicable. This should only be used when accessing C2S (Commercial Cloud Services). If theCAPvalue is specified, then the`-cap-url` must be specified. Seecap-url. [-cap-url <text>]- URL to Request Temporary Credentials for C2S Account-
This parameter is available only when
-auth-typeisCAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword and session token) for accessing the object store server. The CAP URL may look like:https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency=mymission=myrole [-server <Remote InetAddress>]- Fully Qualified Domain Name of the Object Store Server-
This optional parameter specifies the new Fully Qualified Domain Name (FQDN) of the same object store server. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-<region>.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For more information on AWS regions, refer to 'Amazon documentation on AWS regions and endpoints'. For Azure, if the
-serveris a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then the value of azure-account in the configuration followed by a period will be added in front of the server. Note that the value ofazure-accountcannot be modified. [-is-ssl-enabled {true|false}]- Is SSL/TLS Enabled-
This optional parameter indicates whether a secured SSL/TLS connection will be used during data access to the object store.
[-port <integer>]- Port Number of the Object Store-
This optional parameter specifies a new port number to connect to the object store server indicated in the
-serverparameter. [-access-key <text>]- Access Key ID for S3 Compatible Provider Types-
This optional parameter specifies a new access key (access key ID) for the AWS S3, SGWS, IBM COS object stores and ONTAP S3.
[-secret-password <text>]- Secret Access Key for S3 Compatible Provider Types-
This optional parameter specifies a new password (secret access key) for the AWS S3, SGWS, IBM COS object stores and ONTAP S3. For an Azure object store see
-azure-private-key. If the-access-keyis specified but the-secret-passwordis not then one will be asked to enter the-secret-passwordwithout echoing the input. [-ask-azure-private-key {true|false}]- Ask to Enter the Azure Access Key without Echoing-
If this optional parameter is true then one will be asked to enter the
-azure-private-keywithout echoing the input. [-azure-private-key <text>]- Azure Access Key-
This optional parameter specifies a new access key for Azure object store. For other object store providers see
secret-password. See alsoask-azure-private-key. [-azure-sas-token <text>]- Azure Account Shared Access Signature token (privilege: advanced)-
This parameter specifies the shared access signature token to authenticate requests and provide limited access to storage resources in the Azure object store. Any previously stored token will be overwritten by the token specified in this parameter. Pass an empty string in single quotes to clear any previously stored token.
[-ipspace <IPspace>]- IPspace to Use in Order to Reach the Object Store-
This optional parameter specifies new ipspace values for the configuration.
[-is-certificate-validation-enabled {true|false}]- Is SSL/TLS Certificate Validation Enabled-
This optional parameter indicates whether an SSL/TLS certificate of an object store server is validated whenever an SSL/TLS connection to an object store server is established. This parameter is only applicable when
is-ssl-enabledistrue. It is recommended to keep the default value which istrueto make sure that ONTAP connects to a trusted object store server, otherwise identities of an object store server are not verified. [-use-http-proxy {true|false}]- Use HTTP Proxy-
This optional parameter indicates whether an HTTP proxy will be used for connecting to an object store. Note that an HTTP proxy is configured using the
vserver http-proxycommands at thediagnosticprivilege level. [-server-side-encryption {none | SSE-S3}]- Encryption of Data at Rest by the Object Store Server-
This parameter specifies if AWS or other S3 compatible object store server must encrypt data at rest. The available choices depend on provider-type.
noneencryption (no encryption required) is supported by all S3 (non-Azure) object store servers.SSE-S3encryption is supported by all S3 (non-Azure) object store servers except ONTAP_S3. In most cases it is best not to change default value of "SSE-S3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store. [-url-style {path-style | virtual-hosted-style}]- URL Style Used to Access S3 Bucket-
This parameter specifies the URL style used to access S3 bucket. This option is only available for non-Azure object store providers. The available choices and default value depend on provider-type.
[-azure-msi-token <text>]- Azure MSI Token for Authentication-
This optional parameter specifies the new Managed Service Identity (MSI) token required to authenticate to the Azure object store. This form of authentication is only supported on Azure NetApp Files.
The following example modifies two parameters (port number and is-ssl-enabled) of an object store configuration named my-store:
cluster1::>storage aggregate object-store config modify -object-store-name my-store -port 1235 -is-ssl-enabled true
