vserver cifs users-and-groups privilege show
Display privileges
The vserver cifs users-and-groups privilege show command displays privilege overrides assigned to local or Active Directory users or groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified Vserver name.
[-user-or-group-name <CIFS name>]- User or Group Name-
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified user name or group name.
[-privileges <Privilege>,…]- Privileges-
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified privileges.
The following example displays all privileges explicitly associated with local or Active Directory users or groups for Vserver "vs1".
cluster1::> vserver cifs users-and-groups privilege show -vserver vs1
Vserver User or Group Name Privileges
vs1 BUILTIN\Administrators SeTakeOwnershipPrivilege
SeRestorePrivilege
