vserver cifs users-and-groups privilege show
PDF of this doc site
Creating your file...
Display privileges
The vserver cifs users-and-groups privilege show
command displays privilege overrides assigned to local or Active Directory users or groups.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified Vserver name.
[-user-or-group-name <CIFS name>]
- User or Group Name-
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified user name or group name.
[-privileges <Privilege>,…]
- Privileges-
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified privileges.
The following example displays all privileges explicitly associated with local or Active Directory users or groups for Vserver "vs1".
cluster1::> vserver cifs users-and-groups privilege show -vserver vs1 Vserver User or Group Name Privileges -------------- ---------------------------- ------------------- vs1 BUILTIN\Administrators SeTakeOwnershipPrivilege SeRestorePrivilege
