ONTAP commands
vserver cifs users-and-groups privilege show
Display privileges
The vserver cifs users-and-groups privilege show command displays privilege overrides assigned to local or Active Directory users or groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified Vserver name.
[-user-or-group-name <CIFS name>] - User or Group Name
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified user name or group name.
[-privileges <Privilege>,…​] - Privileges
If this parameter is specified, the command displays information only about privilege overrides assigned to local or Active Directory users or groups that match the specified privileges.
The following example displays all privileges explicitly associated with local or Active Directory users or groups for Vserver "vs1".
cluster1::> vserver cifs users-and-groups privilege show -vserver vs1
Vserver        User or Group Name           Privileges
vs1            BUILTIN\Administrators       SeTakeOwnershipPrivilege
                                            SeRestorePrivilege
