ONTAP commands
network interface service-policy show
Display existing service policies
The network interface service-policy show command displays existing service policies.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects service policies that match the specified vserver name.
[-policy <text>] - Policy Name
Selects service policies that match the specified service policy name.
[-services <LIF Service Name>,…​] - Included Services
Selects service policies that contain all services in the specified list of service names.
[-service-allowed-addresses <text>,…​] - Service: Allowed Addresses
Selects service policies that contain all "<service>:<allowed-addresses>" in the specified list of addresses.
The following example displays the built-in service policies.
cluster1::> network interface service-policy show -vserver cluster1
Vserver   Policy                     Service: Allowed Addresses
cluster1
          default-intercluster       intercluster-core: 0.0.0.0/0
                                     management-https: 0.0.0.0/0
default-management         management-core: 0.0.0.0/0
                                     management-autosupport: 0.0.0.0/0
                                     management-ssh: 0.0.0.0/0
default-route-announce     management-bgp: 0.0.0.0/0
3 entries were displayed.
