network interface service-policy show
PDF of this doc site
Creating your file...
Display existing service policies
The network interface service-policy show
command displays existing service policies.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
Selects service policies that match the specified vserver name.
[-policy <text>]
- Policy Name-
Selects service policies that match the specified service policy name.
[-services <LIF Service Name>,…]
- Included Services-
Selects service policies that contain all services in the specified list of service names.
[-service-allowed-addresses <text>,…]
- Service: Allowed Addresses-
"<service>:<allowed-addresses>"
in the specified list of addresses.
The following example displays the built-in service policies.
cluster1::> network interface service-policy show -vserver cluster1 Vserver Policy Service: Allowed Addresses --------- -------------------------- ---------------------------------------- cluster1 default-intercluster intercluster-core: 0.0.0.0/0 management-https: 0.0.0.0/0 default-management management-core: 0.0.0.0/0 management-autosupport: 0.0.0.0/0 management-ssh: 0.0.0.0/0 management-https: 0.0.0.0/0 default-route-announce management-bgp: 0.0.0.0/0 3 entries were displayed.
